VALUE OF BACKHOE
ALLEN
04-10-2003 20:38:03
WHAT IS A 1985 CASE 580D 2WD WOBBLE STICK IN GOOD CONDITION WORTH? I HAVE BEEN TOLD 11,000 DOLLARS TRUE OR FALSE?
Jeff
04-12-2003 10:14:34
 Re: VALUE OF BACKHOE in reply to ALLEN, 04-10-2003 20:38:03
That sounds reasonable, depending on condition.
I bought a 580C, all rebushing'd, vibrator
tamper, and extendahoe, for 14k, with 4k
hours on the unit.
That unit is just a workhorse!
Walt
04-13-2003 15:27:28
 Re: Re: VALUE OF BACKHOE in reply to Jeff , 04-12-2003 10:14:34
Jeff,
How do you go about finding a machine such as yours in the shape and price range that you found your backhoe for?? Yep, this is a naive question, but there must be an art to finding good equipment at a reasonable price. "Machinery Trader" doesn't seem to help, it's just a place to start.
Walt
Walt
04-16-2003 06:43:50
 Re: Re: Re: VALUE OF BACKHOE in reply to Walt, 04-13-2003 15:27:28
Jeff,
Thanks. I'll try to folow your method.
Walt
Jeff
04-13-2003 18:11:31
good olde dumb luck...
I was lucky to find a contractor that had just
plunked 6k into fixing up his backhoe for
one job, and then sold the business.
And yes, I actually had the receipt for the 6k
he put into it (and talked to the shop that
did it.
Honestly, I find its just patience.
Everyone here (in seattle area) told me I'd
never find a good bull dozer for 12k.
I wound up finding a nice Dresser TD7e,
motors abit tired, but 80% undercarriage
for 12500, repainted.
All I've done is rebushing the hand controls,
and tighten up the front wear plates.
Ok, so I should put new pins and bushings
in the front blade, as they are abit loose,
but for the amount I use it, its fine as is.
Also I had a low hours Kobelco 60 fall in my lap,
again, just luck.
I think its just patience, and being ready
when the deal fall sin your lap.
