Brought home a JD 1010C
dan
04-20-2003 17:45:54
Found a 1010C that runs and operates fine, but for the time being i do not have a manual. I would like to check all the fluids and top them off before putting to use. What should I check and what oils should i use?
Jerri
04-22-2003 06:57:47
 Re: brought home a JD 1010C in reply to dan, 04-20-2003 17:45:54
Dan,
Sent some info your way which I believe will help. Would recommend you get the operators, service and parts manuals which will make life alot easier. I own a 1010 dozer, but still going through the tracks before I put her to work.
Take care,
Jerri
DKase
04-21-2003 05:56:03
I have a 1010C with a loader and backhoe. Make sure you have the proper serial # manual as there were three or four different # breaks. Good Luck with the new toy.
fasteddy
04-20-2003 18:30:10
Danny, I have 1010 crawler service book. It covers both the gas & diesel.I can copy the lub section if no one comes back with list.Let me know what you need.
