ATECO Equipment
Jeff Scott
04-11-2001 06:38:10
I am looking for who might have manufactured hydraulic pumps for ATECO. More specifically I have an ATECO bulldozer assembly mounted on a 1952 Oliver BGHS. I spoke with a gentleman at Mountain Implements, the foster home of ATECO and they have not been able to identify the mfg. He relayed to me that ATECO put their part nos. on everything, even bolts, with the exception of pumps. Mine is a gear pump. The valve assembly is Hydreco. I do have numbers stamped into the body and there is some type of emblem cast onto the body but having difficulty deciphering what it is.
Rodger
04-12-2001 09:58:02
 Re: ATECO Equipment in reply to Jeff Scott, 04-11-2001 06:38:10
On my IH and an A/C, the hydraulic pump and control valves are both by Hydreco. If your valve assembly is Hydreco, I'd bet your pump is also. Giving your numbers to a good hydraulic supply firm, with the presumption that they are Hydreco numbers, might be a logical direction to start with.
