Case 310 hydraulic track adjuster? spring tension
greg
05-24-2003 10:26:48
my case 310 has the screw type track adjuster, was this ever replaced or modified to use a hydraulic track adjuster?
I have to replace my track adjusting screws, how do you preload the spring? was going to use grade 8 threaded rod, or was this screw made from anther material?
Ray
05-24-2003 15:37:48
 Re: case 310 hydraulic track adjuster? spring ten in reply to greg, 05-24-2003 10:26:48
Greg,I have a new aftermarket hdy track adjuster that will fit a 310 case. Let me know if interested. Thanks, Ray
Jack
05-25-2003 06:42:14
 Re: Re: case 310 hydraulic track adjuster? spring in reply to Ray, 05-24-2003 15:37:48
There are aftermarket hydraulic adjusters available.
The spring tension is set by tightening the spring retainer. The spring retainer is the round disc with four holes in it that fills the front end of the tube that houses the spring. You tighten that disc until only 1/8th inch of it is showing at the end of the tube. I think the tension is 750 ftlbs. You'll have to make a tool to loosen and tighten that disc.
