Case 530 Backhoe won't move
Gary Beltz
05-28-2003 09:36:26
I just recently bought the 530 and it just stopped moving while I was drive up a small hill. I checked the fluid. It's OK (has some water in it)
Pulled the line off the Clutch Pressure gauge. (It doesn't work) Started it up and a very slow, small stream of fluid came out. I pulled the filter, and watched the fluid flow out of it, again, not too much pressure. I ordered a service manual, but not recieved yet. It's model#: G530 TC
I believe that this is a case-o-matic transmission??? Anybody have any suggestions?
Thanks in advance,
Gary
gm
05-28-2003 12:29:28
 Re: Case 530 Backhoe won't move in reply to Gary Beltz, 05-28-2003 09:36:26
I would just add fluid for that sort of scenario if thats the not problem , then you may have bigger problems. Does the direct drive lever
still work? That should get you going at least. -Greg
Gary Beltz
05-28-2003 12:35:20
 Re: Re: Case 530 Backhoe won't move in reply to gm, 05-28-2003 12:29:28
I've tried the direct drive in both the up and down position. No help. I don't know which way is direct drive. I just got this and still learning how it all works...
Gary
gm
05-28-2003 15:52:49
 Re: Re: Re: Case 530 Backhoe won't move in reply to Gary Beltz, 05-28-2003 12:35:20
How about did you check the hi/lo lever, like below the steering wheel to the right. Mine pops out sometimes going down hill in hi. -Greg
Gary
05-28-2003 16:42:31
 Re: Re: Re: Re: Case 530 Backhoe won't move in reply to gm, 05-28-2003 15:52:49
Yeah, I tried everything! If I put the wheels in the air they will spin, albeit slow and with no torque.
Gary
gm
05-29-2003 07:07:16
 Re: Re: Re: Re: Re: Case 530 Backhoe won't move in reply to Gary, 05-28-2003 16:42:31
Well, I think you have to split the tractor to work on the clutch and/or converter. Lots of work there. I hope you got the machine at a discount. -Greg
Gary
06-02-2003 05:28:31
 Re: Re: Re: Re: Re: Re: Case 530 Backhoe won't mov in reply to gm, 05-29-2003 07:07:16
Got Lucky!!! I replaced the hyd. filter and flushed the lines and all works great!!!
Gary
