Td6 what did i buy?
allan
06-07-2003 21:21:36
folks,
just purchased one, frame serial is tdbk 1554 and the engine serial is tdbk 1216. broke the left clutch housing trying to remove it.:( .can anyone tell me what year the machine is?...thanks
allan
06-09-2003 07:37:02
 Re: td6 what did i buy? in reply to allan, 06-07-2003 21:21:36
thanks Milton and Dozinhal,
seems i've just removed both clutches from one of the EARLY td6's, thanks to the info from both of you. thanks again
Milton
06-09-2003 07:14:45
Hello Allen, --- 9 / June / 2003 ---
Your International McCormick Deering TD-6 (SERIAL NUMBER TDBK 1554) was made in 1940.
The engine was a #248(D) / 4 Cylinders.
Good luck and have fun with it.
Regards, Milton
allan wright
06-08-2003 11:23:48
if somebody has some free advise..i could use some.i'm trying to remove the left clutch..it's frozen up..,got the bearing cage cap loose and all the bolts out of the coupling retainer ring but can't seem to break it out from its position against the pinion bearing. is there something other than the lockwire and bolts to contend with?.thanks. i,ve loosened up the bolts on the track side thinking it may be bound up on the splined coupling but to no avail.
dozinhal
06-08-2003 14:49:24
 Re: Re: td6 what did i buy? in reply to allan wright, 06-08-2003 11:23:48
Alan, take the two halfmoon pieces out and then move the round spline piece they run in towards the track. This can be done by sticking a long big screwdriver in the groove and prying outward. You may also need to collapse the clutch with three homemade retainers to get it out. I know you will need them to get a new clutch back in.
