inter. track loader...trans pump pressure??
03PSD
08-02-2004 20:18:33
Model 150 track loader. What is the pressure supposed to be on the down side of the pump?? my gauge is installed in the top of the filter housing. my gauge is only showing 110 to 140 lbs. i am having trouble getting the tractor to move in foward and reverse and all of a sudden it will go and i will have no problems until i stop it for a while or turn it off. is it the pump or could it be the main regulator in the trans??
Sean
08-03-2004 17:42:34
 Re: inter. track loader...trans pump pressure?? in reply to 03PSD, 08-02-2004 20:18:33
I have a 150 loader, unfortunately I don't know offhand what the pressure should be (my manuals are in storage right now). And the gage on my machine just has green/red zones and no numbers.
I want to say 180 psi, but that's just a guess. Although I do remember that you can increase the system pressure by adding shims in the regulator adjacent to the shifter (I believe). There is a spring loaded regulator valve and if the shims are inserted to increase the preload of the regulator spring, it will increase overall system pressure. These shims looked like little more than washers without holes (in the diagram), so I'm sure you can find them rather easily or adapt a washer etc for the same purpose. Plus the regulator was pretty accessible (under the panel by the operator side) so I believe it should be fairly easy to try if you decide to go that way.
Good luck...
