ASV track quit
2x4
11-11-2004 22:20:46
ASV 2810 right track suddenly stopped working tonight. Left side & loader works great, just all of sudden nothing to the right side. No broken parts I see, no hydraulic fluid leaks. Hydrostatic transmission. Ideas?
Robert in W. Mi.
11-12-2004 18:41:50
 Re: ASV track quit in reply to 2x4, 11-11-2004 22:20:46
If it's like the old ASV's most everything is in the hydraulic tank, so if it leaks, it leaks internally.
Sounds like you need to do some pressure testing to see what's going on.
Robert
John R-IL
11-13-2004 08:06:40
 Re: ASV track quit in reply to Robert in W. Mi., 11-12-2004 18:41:50
I have the same machine. It is probably a cracked line inside the oil tank. The pumps are inside the tank. Take off the lid, lower the oil level a bit and start the engine. You will find out real quick which line is broken. I"ve had to replace the pressure line on both sides over the years. Good luck. Any problems, email and I will help you out.
2x4
11-13-2004 21:22:14
 Re: ASV track quit in reply to John R-IL, 11-13-2004 08:06:40
This is strange. Checked with local ASV shop & they told me a number of things to check. Checked fluid level - full. Started it up but letting it sit overnight made no changes. Decided to inch my way across the level ground by going really slow good track would pull the dead side & after about 50 ft. it started working perfectly?! How weird is that?
John R-IL
11-14-2004 08:01:41
 Re: ASV track quit in reply to 2x4, 11-13-2004 21:22:14
Check oil in final drive unit. May be low or gone and drive unit may be locking up. Check with dealer for instructions and type of oil. Should be changed every year anyway.
2x4
11-14-2004 23:13:49
 Re: ASV track quit in reply to John R-IL, 11-14-2004 08:01:41
Still works fine but tonite hydraulic fluid ran out from underneath the cap, even tho the cap was on tight. Fluid wasn't hot, little warmer than skin temperature but not much. Probably lost a couple of pints of fluid. Flowing out rather forcefully.
2x4
11-14-2004 09:41:05
OK. Thanks; sounds logical
