Case 450 loader
George
09-01-2001 11:23:18
Am going to go look at a Case 450 loader with 4 in 1 bucket. Anything in particular to look for on this machine? Thanks
Max
09-02-2001 10:30:00
 Re: Case 450 loader in reply to George, 09-01-2001 11:23:18
Brakes were usually non-existent which means you would be steering with the clutches in the hi-low mode. Check for slippage in the high range position on these clutches. The early models took DOT3 brake fluid, and had a tendency to spring leaks at the master and slave cylinders. With the loader, you will have to become a sort of contortionist and keep the beer drinking down to two beers a day, for it is a very tight fit to work on the brakes or grease the drive shaft. For that reason you may want to check the driveshaft universals for tightness and grease. Don't mean to discourage for these were really great machines, especially when considering they had the same basic transmission as the larger 850's.
