Case 1150
Zach
09-05-2001 19:24:41
Can you put a screw on oil filter on this kind it has the cooler in side so how could you do this???
Max
09-10-2001 06:43:05
 Re: Case 1150 in reply to Zach, 09-05-2001 19:24:41
Since noone else bit, I guess I will. I assume you are talking about the transmission filter for those can be a real bear to change. I would just replace that housing with a screw on type from a later model. I think it was the 'C' model that finally came out with the screw on filter. It will still be hard to get to though. Good luck.
