Bobcat dies
pappy
10-19-2001 23:06:54
we have a 943 bobcat that has given us no trouble, it has 1300 hours on it and now will only run for 20-30 min. have changed the filters, replaced the transfer pump, and checked the electric fuel shut off.it acts like the fuel is being shut off. sometimes to restart we need to reprime, or just wait a few minutes and restart. hope someone can help, thanks- Pappy
Greg D.
10-20-2001 18:41:29
 Re: bobcat dies in reply to pappy, 10-19-2001 23:06:54
Did you check your fuel cap vent to make sure you`re not getting avacuum in th system?
Zeus
10-20-2001 13:53:18
What were you feedin' that bobcat 'fore he died, Pappy? You cain't feed them wild critters the same over-processed food that we humans eat :<)
Max
10-20-2001 10:48:30
Worked on a Case 850 once that had the same symtoms, finally found a rubber glove in the fuel tank. That was the last thing that I suspected but should have been the first thing I checked, even though when I check the fuel line, it had good flow.
Dave N
10-20-2001 05:26:50
Check to see if you have any blockage or restrictions in your return fuel line. Also pull the fitting out of the injection pump then pump primer or start it up and let it flush. If problem comes back the pump is going out.
Bob2
10-20-2001 18:25:36
 Re: Re: bobcat dies in reply to Dave N, 10-20-2001 05:26:50
Pappy, check all your fuel lines particularly rubber ones for cracks,pin holes,or loose fits. I had a Kubota excavator once with the same problem it was sucking air and after a while would lose power and quit. The unit had new filters clean fuel etc. it would lose prime and die,After alot of searching we found a pinhole in a line letting it suck air. Hope this is some help Good luck.
pappy
10-20-2001 22:24:59
 Re: Re: Re: bobcat dies in reply to Bob2, 10-20-2001 18:25:36
we replaced all the rubber fuel lines and it ran for an hour and seems to be ok now, thanks for everyones help-Pappy
