Thanks for the offer on the manual GN, I'm looking into a 1550B manual now but I might still take you up on it. How do you like your 1400B by the way? I experimented today a little more with the machine and I can see now that it does have a torque converter. If you have it in low gear at idle and release the clutch, it wants to go forward (or reverse depending on where the shuttle lever is put), but it can be stopped by hitting the brakes. Then if you give it some gas, it will overcome the brakes and start moving. If it only had a clutch (that slips) it wouldn't do that, so it seems clear that it's a torque converter machine. It may also mean the idle is set a bit high and that's why it wants to move at idle. Otherwise I ran it through all its gears and it pulls strong in all of them, seems to run great. A lot bouncier and much more top heavy than my crawler, but that's to be expected. The whole machine is incredibly heavily built. It almost seems like some kind of armored vehicle. Big slabs of one and even two inch thick plating throughout the hoe frame, heavy forged members and thick welded steel plate frame with integrated hydraulic tank. And the hydraulics seem massively powerful, I was playing around with the hoe and it easily picks the whole machine up and flings it around with just a twitch of the wrist if you don't watch what you're doing. Overall I'm very impressed, it would be interesting to take a look at some of the Ford's, Case and JD's to see how they're put together in comparison. I'm sure they're all comparable, but this thing is a tank, hard to imagine anyone building a sturdier/heavier unit. Although I've heard the old Dynahoes are serious heavy metal too, almost absurdly overbuilt. Thanks again to everyone for the help, looking forward to getting to know this machine.
