d47u
7ud4
03-05-2006 18:10:53
I have a d4 7u that I just got the track back on after having the adjuster break. The adjuster is threaded out about 3 3/4'' and still could use a few more turns. This is were my problem starts I don’t know why its out so far the sprocket is good rollers are good idler is good the bushing are just starting to flat spot not ready to be turned. So I counted the track links and came up with 32 my parts book says 31 so should there be 31 it has solid idlers. Two other things I see I can wiggle the pads side to side does this mean the pins are worn? Also the other side has spacers between the arm and the idler bearing housing part #4b8649 should they be there or is to make up for wear?
Hector gemme
03-06-2006 02:32:59
 Re: d47u in reply to 7ud4, 03-05-2006 18:10:53
HI Some d4 have 32 pad and you chaines need just 1 inch loose went you adjusted theys and check your idler enlignement. HECTOR
