450 Case broken output shaft
Dan-O
11-11-2001 17:37:00
I was moving my 450 case (s/n 3040969) when the output shaft broke in the middle just before the splines. When it broke the shaft flange and sprocket came loose from the final drive. From the size of the shaft I was very shocked. What could have caused this to break down and is this nornmal? Also, if anyone knows where somebody that is parting out a 450 case, please let me know. My shaft is the type which uses the two seals and two L-shape washers. Thanks for any help. Dan
M.R.
11-15-2001 09:22:21
 Re: 450 Case broken output shaft in reply to Dan-O, 11-11-2001 17:37:00
Construction Equipment Parts Co. 1-800-727-8787 www.ceparts.com
Balanda Equipment, Inc
1-800-322-8030
Head Equipment, Inc
800-338-5178
marlowe
11-11-2001 17:41:15
if close to wi. this place has one they are parting out 1-800-242-2028 they also ship
Dan-o
11-12-2001 08:26:56
 Re: Re: 450 Case broken output shaft in reply to marlowe, 11-11-2001 17:41:15
Thanks Marlowe, I'll give them a call.
Dan-O
11-14-2001 18:29:47
 Re: Re: Re: 450 Case broken output shaft in reply to Dan-o, 11-12-2001 08:26:56
Marlowe, Thanks for the dealer's phone number. He had a shaft for the new type, but at the current time, he did not have the type I needed. Thanks, Please let me know if any other numbers in mind. Dan-O
