D2 CAT
AJ 77
07-09-2006 21:59:54
Looking for instruction on a clutch problem. Has been running fine with daily use the last 4 weeks, now when you engage it, the clutch slips and the problem seems to be getting worse. Wondering if there is an adjustment I can make or if something just needs to be replaced.
hectorgemme
07-10-2006 02:10:41
 Re: D2 CAT in reply to AJ 77, 07-09-2006 21:59:54
HI Yes you have a cluch adjustement on d2 remove the inspection plate on top of the transmission case cover. Reach through this opening and turne the cluch adjusting collar until the lock pine can be reached .Engage the transmission gears and pull the lockpin and tighten by turning the collar to the right or clockwise until thelock pinedrop in next hole and test the adjustement by angaged the cluch.
