1010c
Mike Little
11-22-2001 18:00:25
Will the engine from a john deere 45 combine fit and bolt up to a 1010c crawler tractor.
440Sam
11-29-2001 17:54:23
 Re: 1010c in reply to Mike Little, 11-22-2001 18:00:25
The early 45 combine (round back) engines (JD145 Power Unit) will work (same as a 2010) however the 1010 engine was the same as a JD115 Power Unit that was in a 40 Combine and the 600 Hi Boy Sprayer. If you use a 45 Combine engine you will have about 10-15 more horsepower and premature driveline failure. This info is for gasoline engines. Hope this helps, Sam
Steve
11-23-2001 17:42:28
Mike, yea , I've heard that will work. What's going on with your engine? I need some part's Steve
