master track pin removal td20
63musketeer
09-23-2006 15:58:49
Hello,
On a td20 dozer does the pin gets removed from the inside out ?
I removed the 1/4 lock pin ...What way does the pin come out ?
Any tricks in getting this pin out ?
Thanks A
63musketeer
09-24-2006 19:19:40
 Re: master track pin removal td20 in reply to 63musketeer , 09-23-2006 15:58:49
Well I need to say THAT PIN IS TIGHT!!!!
I will try to make some kind of press
this week..
Thanks for the help I'll let you know how it works out..
A.
l galvin
09-24-2006 11:07:21
On my TD-6 the pin is driven out from the lock pin side. One track goes from the outside in and the other it goes from the inside out. If your pin is oval shaped on one end and round on the other then you have to push on the oval end. They can be tight.
lg
no neat sig line
hectorgemme
09-24-2006 03:38:26
HI The pine comme out inside and if you dont have a hydrolique press you can use a big sleege and hammer pine.
