1010C questions on year
greg
12-28-2001 18:29:34
I have a question on 1010 crawler serial numbers and year of mfg. I have a dozer serial 19024 so I am told this is a 1961 machine because it starts with a "1". Ok, I bought a 1010 bucker loader today but its only a 4 digit serial (25xx I think). Since its only 4 digit, does this mean its a real early machine, first year of the 1010C??? I assume this is the case. Also, what is the first year of the 1010C? 1960 or 61?? Thanks, I may have more questions later. It has the shifter on the dash (earlier machine per the parts book) Thanks, Greg
greg
12-30-2001 15:34:35
 Re: 1010C questions on year in reply to greg, 12-28-2001 18:29:34
Forget the question about the year of the 1010C. Better sanding and cleaning of the serial plate revealed a 5 digit serial of 21351 which makes it a 1962. The question of one being 12v pos. ground and the other 12 v neg. ground still stands. The 61 is pos ground and the 62 is neg ground. Any ideas if the changed between 61 and 62?? Thanks. Greg
greg
12-29-2001 11:23:37
Another question I have on these same 2 machines. One is positive ground 12 volt and the other is negative ground 12 volt. Is this right? Seems like they should be the same.
