Re: JD 410 hard to start
jim boettcher
09-28-2007 09:16:56
I give it full throttle when first cranking. When it starts to fire I back off. If it doesn't want to fire at full throttle I just start backing off while still cranking. That's on a John Deere Diesel. On my Fordson tractor I had the same problem as you for years until I read my book and it talked about pressing the button on the fuel injector pump for fast, easy start.
DA! I have thrown away my starter fluid. All the button does is give it a full dose of diesel until it fires and then the button pop's out on it's own. By giving your's full throttle when first cranking your doing the same thing. Also,
don't forget to keep your air filters clean as clean can be. Mine are clean-able by blowing out with compressed air. They will give you problems big time when trying to start if dirty. I ALSO USE FUEL ADDATIVE AT ALL TIMES. Let me know if this helps. Hope so.
Myassitis from Mo.
ChrisB
09-28-2007 09:35:27
 Re: JD 410 hard to start in reply to jim boettcher, 09-28-2007 09:16:56
Jim,
Good thinking on the full throttle, I will definitely give it a try. Filters are new with very few hours on it so I am safe there.
Since you are having good luck, what kind of additive are you using? I forget what I am adding now as I seem to switch between brands and cannot settle on one.
Thanks again,
Chris
