stuburn fork lift
w bowley
03-14-2008 10:33:54
i have a problem with a cat fork lift propane acts like it is flooded when at first started then clears out.sometimes stalls and is very hard to start,there is a button on the diaphragm if i hold this in while trying to restart it seems to help. can someone give me some help as to what the problem is. thank you
Billy NY
03-14-2008 16:20:53
 Re: stuburn fork lift in reply to w bowley, 03-14-2008 10:33:54
Does it have a vaporizor type regulator, like an Impco model J ? They're a cinch to clean and rebuild, kits are available on the web for them, seen OEM ones on ebay. My LP tractor used to act up like that all the time, until I rebuilt the vaporizor.
edevoll
03-14-2008 12:17:31
I assume your talking about a LP gas fork lift.
That being the case I'd suspect the regulator is clogged up. We have to clean them out regularly because of the dirty propane I guess.
