CASE model 26C backhoe question
steve n carol
03-17-2008 21:47:01
Got to play with this hoe that is mounted on the back of my 450 crawler. I don't have much experience w/this hoe. Today I noticed somthing unusal and thought I'd ask those w/more experience if they might shed some light on this.
The stabilizers are weak and wont lift the machine, (much), until it move both of them at the same time!? [one full down, engine lugs down. then just tap the left stabilizer lever and PLENTY of power then! Not 'hose poppin' power, but power like it should have. Also, when I lift the back of the tractor w/ the hoe, to scoot it forward, that too is week. until I move one of the other levers.??
This is as normal operating temp, on level ground, running aprox 1700-1900 rpm's (diesel eng). the filter/screens, are clean. hyd fluid is clean. normal lifting capacity with the loader. HOWEVER, the loader lifts better at an idle?? I did read that this could be caused by clogged screens/filters. But they are clean. even the intake screen inside the hyd tank. I had it off 2 weeks ago.
I do believe (from memory) that they are CASE bk hoe valve/s assembly.
nothing is leaking, not even seeping. There should be more breakout force too. I have used other hoes in the past that have plenty of poop.
any thoughts???
I am thinking that the hoe has always been like this. I don't use it, the hoe, much and usally have it off of the crawler.
I would suspect the hyd pump might be worn some, except the power is there when you use the second lever a bit at the same time.....
thanks, and sorry about the long post....sl
