D4 7U clutch problem
Idaho Tom
03-28-2008 11:02:22
The clutch on my D4 is slow to disengage. Is there any way to correct the problem?
hectorgemme
03-30-2008 16:39:11
 Re: D4 7U clutch problem in reply to Idaho Tom, 03-28-2008 11:02:22
You should have on the brace collar a funnel 1a1379 and on the floor a oil cup 4b457 for lubrification.
hector gemme
03-30-2008 03:01:17
You have to check the brass collar maybe he miss lubrification and he is to worm.
Bob Plumadore
03-29-2008 18:32:56
What do yu mean by slow to release, slow to stop turning so you can shift? If so adjust the stop brake
a lot of these old tractor you have to put your foot on the master clutch lever to hold it tight to the brake
Idaho Tom
03-30-2008 07:58:55
 Re: D4 7U clutch problem in reply to Bob Plumadore, 03-29-2008 18:32:56
My Cat is moving in forward, I pull the clutch and it takes several seconds for it to stop.
hector gemme
03-30-2008 11:05:04
 Re: D4 7U clutch problem in reply to Idaho Tom, 03-30-2008 07:58:55
You have 3 spring in the pressure cluch when the cluch is is desangaged the springs force the two pressure plate apart and hold them in that position. A brake is provided to bring the rotating cluch shaft to a stop quickly when the cluch is desangaged.
Idaho Tom
03-30-2008 15:26:22
 Re: D4 7U clutch problem in reply to hector gemme, 03-30-2008 11:05:04
hector gemme said: (quoted from post at 11:05:04 03/30/08) You have 3 spring in the pressure cluch when the cluch is is desangaged the springs force the two pressure plate apart and hold them in that position. A brake is provided to bring the rotating cluch shaft to a s
can you tell me how to grease the cluthc parts
hector gemme
03-28-2008 12:59:19
Let me know if your d4 7u use a wet or dry cluch. gemdozer@hotmail.com
Idaho Tom
03-29-2008 16:33:38
 Re: D4 7U clutch problem in reply to hector gemme, 03-28-2008 12:59:19
d 4 7u has a dry clutch
hector gemme said: (quoted from post at 12:59:19 03/28/08) Let me know if your d4 7u use a wet or dry cluch. gemdozer@hotmail.com
PD Mechanical
03-28-2008 12:05:30
Tom: I am not real familiar with the 7u series but I believe there is a clutch brake. This may need adjusting or repair. Again I'm not familiar with that series so I can't help with the procedure. I'm sure someone will be along with the answer though. Good Luck. Steve.
Gary B Down Under
03-29-2008 19:16:02
 Re: D4 7U clutch problem in reply to PD Mechanical, 03-28-2008 12:05:30
Tom, Hi i have a D2 4u and a D4 6U which is the same as a 7U only norrower, there is no adjust ment for the fly wheel clutch brake, as the brake pad is bolted to the front of the transmission case and the contact surface is the rear of the sliding collar (throw out part of clutch as) all i can sugest is to remove the top half of the cluch housing and in spect the brake pad and all the link ages for wear. you may have to hold some pressure forward on the clutch lever to get the brake to work with worn linkages, as i have to with me D2. the best picts are the ones in a parts book if you have one avaliable.
regards Gary B
