D-7 cooling system
0zzie
04-04-2008 02:46:05
Need some help guys.Have a D-7 48 A pukes coolant out of weep hole in water pump replaced water pump still does it.The thing is if I get it running and keep it running it doesnt seem to do it,but run it for a while then let it idle for 10-15 minutes and go back to work it pukes coolant out weep hole.Coolant pressure gage shows hi pressure, not geeting coolant in crankcase.Any help would be very much appreciated.
Bob/Ont
04-04-2008 17:13:22
 Re: D-7 cooling system in reply to 0zzie, 04-04-2008 02:46:05
Make sure your pressure relief valve is working. Under raised round cover top center of rad tank. Pressure should blow coolant out there before making pump leak. I have had problems with those rebuilt pumps if they don't put sealant around the seal when installing it.
Later Bob
