Re: Installing track pads?
Jonathan in MA
04-07-2008 15:27:04
no real rocket science... just time consuming. Not sure what size tracks your dealing with either. If you do it yourself, you should sand the paint off of the track chains as well as off the surface of the pads where they attach to the chain.You will also be removing any high spots where the holes were punched in the pads. By doing it yourself, you'll know it gets done. If theres an appreciable layer of paint on both, the pads can loosen up when in use and once they loosen, they seem to never stay tight afterwards..
