Case 310G Tracked Frontend Loader.
Okiejack
04-08-2000 21:35:05
I have a Case 310G Tracked frontend loader. I am restoring it to use.
I've been through the transmission, differential, final drives, and undercarrage. The clutch is great exercise for my left leg BUT, I want to install a powershuttle transmission.
Any one know if this is feasible. I have heard that the powershuttle will install just by removing the bellhousing and clutch and shortening the driveshaft. That the powershuttle is the major difference between the 310 and the 350.
The original tractor has a three speed transmission. Transmission and differential and steering brakes are all in one case. Tracks have 33 pads one foot wide. Spoked sprockets and idlers. Five bottom rollers. 188 four cylinder diesel engine. Can't locate the serial number.
Any help would be appriciated.
Jack
zack
10-07-2002 10:20:18
 Re: Case 310G Tracked Frontend Loader. in reply to Okiejack, 04-08-2000 21:35:05
I need trans./differential if you decide to sell those parts.
