Re: T340 hydrolic problems
T_Bone
01-29-2001 17:47:24
Hi Al, I would think the spring and plug in the strainer would be a by pass check if the screen becomes plugged. Could have someone installed a smaller strainer than whats called for? Is the tank vented? If not that maybe where your getting some foam but your going to get some no matter what because of the fluid flow. If it's not excessive I wouldn't worry about it.
I haven't worked on your type of system but just general thinking.
T_Bone
340 Al
01-30-2001 07:37:28
 Re: Re: T340 hydrolic problems in reply to T_Bone, 01-29-2001 17:47:24
Hi T Bone. Thanks for the interest. The spring and plug is a by pass. But it's attached to the screen. Normally, all fluid passes through the filter. If the filter is clogged, the spring/plug will release under the suction and allow fluid to pass through the screan and into the pump. The filter element and the oil are the only things changed from the time it worked OK 'til now when it sings a song of woe.
T_Bone
01-30-2001 13:09:48
 Re: Re: Re: T340 hydrolic problems in reply to 340 Al, 01-30-2001 07:37:28
Hi Al, From what you've said it would appear there's something wrong with the new filter. I ment filter when I said screen. I don't think the filter can be installed backwards? And even it was I don't think it would cause your problem. There's a problem with the new filter from what you described because you removed the by-pass and that solved the problem. I can't think thats it a oil problem because it pumps fine with enough unrestricted suction. You have a weird one and when you find out, be sure and post the results. T_Bone
