656 Hydraulics
Randy
02-01-1999 08:45:45
My 656 has two hydraulic hoses running up behind the seat. What would have to be done to put a front-end loader on it? Is there a hook-up for another set of hoses somewhere?....
nick
05-03-2004 20:35:02
 Re: 656 Hydraulics in reply to Randy, 02-01-1999 08:45:45
the 656 I have has a set of remote couplers under the fuel tank so I am sure if you don't have that you could go to a tractor salvage yard to get the 2 spool valve and the plumbing for it. Also you could just get longer hoses for the loader and a 4 way valve and hook up to the remotes on the rear of the tractor. other than that a loader should bolt right up to that machine.hope this helps
Hoosier
02-01-1999 11:37:28
It depends on how many remotes your tractor is equipped with. How many hyd levers are there? there should be the one for the hitch, then the ones (or one) for the remotes in front of it. The 656 has plenty of hyd capacity for a loader.
Norm
02-01-1999 10:31:09
Use a pto pump you will be much happier
