Delco Remy distributor
bobbgood
02-28-2001 16:24:34
On a 1946 M does a Delco Remy distributor use the same condensor as IH distributors? The electrical system is 12 volt negative ground. My concern is a condensor for 6 volt system being used on a 12 volt system with a ballast resistor. Help and opinions are welcome.
haleyhat
05-25-2005 18:19:06
 Re: Delco Remy distributor in reply to bobbgood, 02-28-2001 16:24:34
I am looking for a bushing for a delco remy distributor on a 1947 M Farmall. Thanks for any help.
artie
03-01-2001 17:40:07
makes no difference. their interchangeable.
spyder
02-28-2001 16:32:11
you need a 12v auto resistor coil any kind will do
one off a old chevy or something if not you will burn your points.
