Need help identifying year of Farmall F12?
Adam Davis
03-12-2001 06:35:11
I went back to look at the Farmall F12 I found and took the serial number down in my head. It is FS44249 if I remember right. I don't quite remember if the FS was on the serial number or somewhere else on the tag but it was on there I think. I also got to looking closer at the tractor and the gas tank is good on the top and sides but is shot on the bottom. There are also a few smaller parts that are missing. The steering still turnable, I can move the transmission lever in and out of gears without any trouble, also the motor is froze but I don't think it is froze too tight! Another question is can a belt pulley be added to these tractors? Thanks for any help Adam Davis This is the link to the picture of the F12 I found. Tell me what you think.
http://www.ytmag.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.ytmag.com/gallery/tphotos/a2013.jpg&firstrec=1&lastrec=15&Parameter=F12&mode=All&what=tphotos
John
03-14-2001 23:19:09
 Re: Need help identifying year of Farmall F12? in reply to Adam Davis, 03-12-2001 06:35:11
Try here for serial numbers.
http://www.sckans.edu/~alan/intharsn.html
Bill B
03-12-2001 18:28:12
third party image
I also have a 35 F12. They should be gray to be correct, with red wheels. The pulley was often removed by the farmer when he did not need it, because unlike other farmalls, there is no way to take it out of gear. It runs whenever the clutch is out. This not only makes it more difficult to line up the belt, but the pulley is heavy enough to act like a flywheel, and when you have the tractor running in neutral,a nd push in the clutch it takes a long time for the gears to stop so you can shift into gear. Most of them were probably still in the machinery shed when the tractor was sold, and so most of them are lost. I have had several F12s and only one had a pulley.
Farmallboy
03-12-2001 15:25:22
WOW,your F12 is only 51 higher than mine.Mine is FS44198.Like JRM says there is a ton of parts out there for them.The belt pulley was a factory option.So its real easy to put one on it.
JRM
03-12-2001 14:12:07
Fs is the serial number prefix. That tractor would be a 1935. There are a ton of parts available for the F12 and F14. Have fun.
Andy Tucker
04-20-2003 16:13:55
 Re: Re: Need help identifying year of Farmall F12? in reply to JRM, 03-12-2001 14:12:07
Where do I look to find the serial number on a Farmall F12?
