H cutter size
rhudson
03-30-2001 18:23:51
i'm looking for a pull type rotary cutter for my H. want it to play with mosly, cut broom straw, no heavy cutting. there is a 5' jd nearby for $200. i think its going to look silly behing the H. will it pull a 6 foot or should i go for the 5'? thanks for the help.
Denny Frisk
04-03-2001 11:05:50
 Re: H cutter size in reply to rhudson, 03-30-2001 18:23:51
I used to pull a 6 ft. Brillion with my Super H. It was a LOAD if the grass/weeds/whatever were tall. We used the rotary to mow hay for a few years. 3rd gear, about 5 mph was as fast as I wanted to pull it in good alfalfa. I could chop corn stalks in 4th, about 6-1/2 mph. Your H should be able to pull the 6 ft. in the same gear, just slower. The 5 ft. jd wouldn't be able to mow out your wheel tracks, but if its in good shape, the price seems O-K. Be Careful!
Bill Rymer
03-31-2006 14:21:30
 Re: Re: H cutter size in reply to Denny Frisk, 04-03-2001 11:05:50
The Brillion 6 ft cutter -- Any of you know where I can come up with a gear box for the pull-behind 6 ft Brillion rotary cutter ? It is also behind an "H."
rhudson sorry for double post
03-30-2001 18:25:39
sorry maybe its me but i,m going to blame the computer
