Order Farmall Cub Parts Online
Now I have spark on my 1948 cub from the auction
Glenn
04-03-2001 13:21:03
Thanks for all your wonderful suggestions, I now have spark but the mag needs timing. I do have a book but shows only one mark on the pulley, but I have two marks. How do I time the mag to see if this old cub will run again? It has the orginal coil on it by the way. Maybe I got a pig in the poke at the auction!!!
Bus Driver
04-03-2001 16:14:56
 Re: Now I have spark on my 1948 cub from the auction in reply to Glenn, 04-03-2001 13:21:03
As you turn the engine with the crank, the SECOND mark that passes the pointer soon after the first is the TDC mark. Static (not running) time it on the second mark. At 3/4 or better throttle, a timing light will flash on the first mark, indicating proper spark advance.
