Heisler 9-speed for H
jmyt_47
04-19-2001 07:29:48
I just picked up a used heisler 9-speed out of a '42 H for my '39 H. Unfortunately it was already removed from the H's transmission case. I have been unable to find any diagrams detailing the assembly. Would the Case/IH dealer have any info? According to the seller, I have all the pieces, and it worked before he disassebled the the tractor. I have a M&W 9-speed manual with the diagrams, but it only helps so much. I did take note of the hole for the shift linkage, which was on the left side of the trans case. Now I just need help with putting it all back together, especially the shifting collar locations on the gear set. I do have the parts separated between the upper and lower shafts. Does anyone have any photos of this setup? With the trans deck off? Or an old parts manual for it?
Any help would be appreciated!
thanks
