Greasin td6
gm
06-14-2001 15:23:12
Heyas,
Just wondering where to buy a bucket
greaser fitting for my grease gun. It is supposed to fit the weird grease
fittings on this dozer. I figure I
need to get the parts of the track
greased up at some point.
as for what it looks like, it is quite a
bit bigger than a standard grease fitting.
Probably like 1/2in. diamater, with a smaller circle in the middle.
Thanks for any info
Andy Martin
06-14-2001 17:15:33
 Re: greasin td6 in reply to gm, 06-14-2001 15:23:12
That's called a button head grease fitting. The circle in the middle is where the grease goes in.
You can get a tip for your grease gun from most heavy equipment dealers or industrial supply houses.
It slips sideways over the large disc and has a rubber seal which surrounds the middle hole. Grease the track regularly.
