Farmall 300 vs. Farmall M
Ralph
06-20-2001 19:48:20
Will a 300 outpull an M
Justin Kuck
06-21-2001 04:52:39
 Re: Farmall 300 vs. Farmall M in reply to Ralph, 06-20-2001 19:48:20
No the 300 is the newer version of an H so it will have less power than an M
john d
06-20-2001 20:54:54
If you're talking about putting them in the field with tillage equipment, the M will work the 300 into the dirt.
While the 300 is about the same physical size, and is newer, the M has a larger engine, probably weighs more, and may have larger tires. The gear ratios for 2nd, 3rd, and 4th gears are closer on the M than the 300, giving the M somewhat of an advantage on finding the optimum tillage speed. If the 300 has a good TA, that will help, but not enough.
By this time, the 300 and the M have likely been overhauled at least once or twice, and have probably received some engine parts that increased the power somewhat. Here again, the M has the advantage, as the overbore kits for the M increased the displacement to 264 cid, a bigger increase than the 300 got from its kit. The 300 Utility came from the factory with the rpms set higher than the row crop units. Within weeks, lots of farmers had turned the row crop tractors up to the same rpm limit as the utility models (about 2100 or so) and got some hp increase. Even that isn't going to put the 300 ahead of the old M, however, as a large percentage of those monsters have had the governor opened up to let them run 2000 rpms or more. (I've got one that's been faster than that since 1964, and I can't see that it's hurt it much!) Factory hp ratings were very close, but some of the old M tractors now push out close to 50 hp, a few even more!
The 300 will have better hydraulics, and the live pto found on most models makes it more versatile. On a pto job, a good 300 can come close to holding its own against the M, but by the end of the day, it will have worked harder!
Red Rider
06-20-2001 20:48:30
I have 300 Farmall that I pull in the stock tractor pulls. I Pull in the 5000/6000 and the 6000/7000 classes. I pull against a lot of M and Super Ms. The super Ms are hard to beat but the Ms I can usually beat. The one advantage a 300 has over the M or Super M is the low side of the TA. Where the M or Super M will run out of power I generally will run out of traction.
Dave T
06-20-2001 20:22:26
The Farmall 300 is the third in the run of the Super H. The Farmall 300 has around 37 some Hp and the M has around 39. The M seems to have a heckuva lotta torque. They get the extra horses from the extra rpm and tighter compression ratio. The M has 248 cu. in, and the 300 has 169
FARMALL ED
06-20-2001 19:57:50
I AM NOT EXACTLY SURE BUT I THOUGHT THE 300 WAS THE AFTER RUNNER OF THE H.IF THIS IS THE CASE I DONT BELIEVE IT WOULD OUT PULL AN M THAT IS IN GOOD SHAPE.ED
