706 wont start
scooterhead
06-25-2001 16:11:53
I was mowing hay , about 4 hours , stoped to talk to somone and it started to sputer a bit then smothed out then again then died before I could get back to it . There was plenty of fuel in the filters , there was alot of air at the pump but after bled out it wont pump into the injector lines . It was running fine .706 Farmall , 310d engine with Bosch pump
Dan
06-25-2001 18:33:59
 Re: 706 wont start in reply to scooterhead, 06-25-2001 16:11:53
Yopu might try bleeding the lines at the injectors. Doesn't explain how air got in there to start with if plenty of fuel in tank and all. You might also change filters.
ken pagel
07-12-2005 23:16:44
 Re: Re: 706 wont start in reply to Dan, 06-25-2001 18:33:59
how do you bleed the lines at the injectors
