Hyd.pump
SheldonMT
07-05-2001 14:37:43
Help have a Super H with a Behlen distrubitor drive hyd. pump. I need a seal and gasket kit for. It has a casting number of 201, if this helps. There as been many of these used on older Farmall's with Behlen power steering motor on the steering shaft. I have been told that IHC put this system on thier older cotton picker. Thanks for any help. Sheldon
Les Repair
07-05-2001 17:33:12
 Re: Hyd.pump in reply to SheldonMT, 07-05-2001 14:37:43
I'm pretty sure you will be disappointed when you take that pump apart. There will be needle bearings which fall apart when you take it apart and there may not be parts available. The seals can be gotten be crossing the seal numbers. Good luck.
George Mikesell
09-11-2004 19:48:59
 Re: Re: Hyd.pump in reply to Les Repair, 07-05-2001 17:33:12
The needle bearings are Torrington bearings, and can be gotten at beearing supply house. In most cases there is a no on the bearing, normally starting with a B like B1516. Also you can go by shaft size,plus housing bore and width.
