Charge it, please...
HavinFuninMo
08-13-2001 11:50:02
Hey, Finally got around to replacing a bad voltage regulator on my F - 140. I am having a hard time finding a 6 volt, negative ground regulator. My local Case IH dealer tells me that they never made a 6 volt negative ground system. Is that so? The system sure looks original. If I can't find a negative ground regulator(Have been to all the local auto parts & tractor supply stores), what do I have to do to change it to a positive ground system? Thanks in advance for your help.
Bob M
08-13-2001 12:51:05
 Re: Charge it, please... in reply to HavinFuninMo, 08-13-2001 11:50:02
Changing to positive ground is straightforward:
1 - Remove the cables from both battery posts.
2 - Swap the wires at the two ammeter posts (or you can ammeter wiring as is - it'll just read backward if you don't swap the wires)
3 - Install/connect the new regulator.
4 - Reconnect the battery with the POSITIVE post grounded.
5 - Polarize the generator: Momentarily connect the BAT and GEN terminals at the regulator.
You now should be set to go...
HavinFuninMo
08-13-2001 13:25:58
 Re: Re: Charge it, please... in reply to Bob M, 08-13-2001 12:51:05
Thanks Bob. Couple follow up questions to ensure I got this right. The regulator is the only piece of hardware that really "cares" if it is positive or negative ground? Do I need to drain the battery and recharge or does it not change anything with the battery other than which lead goes where?
Thanks again
Bob M
08-13-2001 14:04:14
 Re: Re: Re: Charge it, please... in reply to HavinFuninMo, 08-13-2001 13:25:58
You got it! Only the regulator cares whether you're positive or negative ground. You don't do a thing to the battery - just reconnect so the ground cable is on the battery positive (+) post.
Incidentally the ammeter doesn't care about grounding either - it simply reads backward (deflects to the left for charge and right for discharge) if hooked up with the ground reversed.
Now "have fun"!!
graytinker
08-14-2001 01:33:48
 Re: Re: Re: Re: Charge it, please... in reply to Bob M, 08-13-2001 14:04:14
Bob if I`m not mistaken if you have a disturbuter ingnition system you will have to change the coil wire`s to or you will burn the points.
Bob M
08-14-2001 04:33:48
 Re: Re: Re: Re: Re: Charge it, please... in reply to graytinker, 08-14-2001 01:33:48
Hey Graytinker - Good catch! I forgot to mention changing the coil polarity...
On the other hand it's been my experience the coil will work fine and the points don't burn even even if coil primary polarity is wired backward. So there's no real harm if you neglect to swap the coil primary wires. ...Bob M
graytinker
08-14-2001 01:32:53
