Lighting....
'Bandit'
09-02-2001 20:56:59
Thanks for the help on the fan pulley. Turns out, i took the radiator off and oiled the fan a little and she broke loose. Works great now, not to say it won't need replaced eventually, but it works for now.
I need to add a set of work lights to my 'A' what would i run the wire from the light to? directly to a battery terminal? There are no hookups for the lights on the existing wiring, this would be a completely auxilary set of lights... with an on off toggle switch. any suggestions?
Bob M
09-03-2001 06:59:52
 Re: lighting.... in reply to 'Bandit', 09-02-2001 20:56:59
Bandit - Better to pick the lighting feed from the ammeter terminal that connects to the regulator (or cutout relay), NOT direct to the battery. Otherwise you'll get false ammeter readings whenever the lights are on.
For safety recommend putting a 20 amp fuse in the line ahead of the light switch too!
J3nut
09-03-2001 06:25:52
I would run the wire directly from the battery, through the toggle switch, to the lights. Just make sure you have a good ground and you should be set.
