Order Farmall Cub Parts Online
Belt routing on belly mower for farmall cub
Tractor Man
09-08-2001 07:24:39
The drive belt for the belly mower recently slipped off while mowing and I have no idea of how to re-route the belts. Can anyone give me any information?
Thanks....
keith
09-09-2001 03:52:05
 Re: Belt routing on belly mower for farmall cub in reply to Tractor Man, 09-08-2001 07:24:39
I have a 4 foot belly mower on my cub and it only has one belt. If this is what you have, the belt should loop over the pto pulley, run under the two verticle idle pulleys and then wrap around the pulley on the mower.
Phlogiston
09-08-2001 16:39:51
I have a C-2 mower (1 large belt) on my Cub. If this is what you have, let me know and I can help you.
Phlogiston
pat
07-07-2004 10:58:43
 Re: Re: Belt routing on belly mower for farmall cu in reply to Phlogiston, 09-08-2001 16:39:51
I have a 39 farmall cub with a belly mower. It only has 1 belt. The mower deck has 5 pulleys. 2 single ones and one 3 tier stacked. The mower is new than the tractor. I need the belt rounting.
