Flat head Waukesha, IHC U-9 and Leroy power units, are they worth parting out??
Texas Red
09-09-2001 12:36:38
I have located therr puwer units, A flat head Waukesha, and a Leroy and Ihc u-9. Were there any tractors that used the engines and are they worth the time and money to haul the in and part out? The U-9 and the leroy are most likely stuck, the Waukesha has the stack coverd up. Thanks for any help you can give. TR
Bob M
09-09-2001 15:32:11
 Re: Flat head Waukesha, IHC U-9 and Leroy power units, are they worth parting out?? in reply to Texas Red, 09-09-2001 12:36:38
Depending on the size, the Waukesha flat head could have been found in a few Oliver and IHC tractors - also in some Hubers, Bates crawlers, etc. The U-9 is the same motor as used in the IHC W-9 wheel tractor and T-9 crawlers. Don't know about LeRoi motors - I've seen them in old air compressors, graders, etc but don't ever recall seeing one powering a tractor.
Unless they're really beat up and missing parts, I'd submit the motors are worth salvaging and parting out.
Peter 57
12-30-2004 16:20:43
  Re: Flat head Waukesha, and Leroy Engines. in reply to Bob M, 09-09-2001 15:32:11
I own a old LEROY 2 cylinder water cooled engine with side covers and a flat pulley and do not know any thing about them. Where could I get info. YEAR,HP,MAKES,MODELS,MISC. ETC.
My friend has a WAUKESHA 4 cylinder flat head water cooled engine, pull start with a mag. on a frame with a small water pump.
I am trying to get the same type of info. on it.
(Either any good for a garden tractor puller?)
If anyone could steer me in the right direction it would be greatly appreciated. !!!!
