Dry-ssleeve engines
C.L.
10-12-2001 13:53:51
Did any IH diesels have dry sleeves?
Andy Martin
10-12-2001 16:13:15
 Re: dry-ssleeve engines in reply to C.L., 10-12-2001 13:53:51
All of the MD, WD-6, and WD-9 diesels are dry sleeve.
Jon
10-12-2001 17:35:48
 Re: Re: dry-ssleeve engines in reply to Andy Martin, 10-12-2001 16:13:15
The D-DT-361 and D-DT-407 are dry sleeved.
J.D. Humm
10-12-2001 18:42:45
 Re: Re: Re: dry-ssleeve engines in reply to Jon, 10-12-2001 17:35:48
Some of the smaller engines (diesel) such as D188, D282, some other older diesels and also 361 and 407 as already stated. I kind of liked them better than the wet sleeved engines. Seems like they lasted longer. No cavitation due to electrolysis as is a problem with wet sleeved engines.
Jon
10-12-2001 20:03:49
 Re: Re: Re: Re: dry-ssleeve engines in reply to J.D. Humm, 10-12-2001 18:42:45
I've often wondered why IH went to the wet sleeve engine after the 361 and 407's. Sure don't hear about the later 414,436,466 etc having as many hours before a rebuild as the dry sleeve engines.
J.D. Humm
10-13-2001 10:24:35
 Re: Re: Re: Re: Re: dry-ssleeve engines in reply to Jon, 10-12-2001 20:03:49
Yes, I know. The old 361 and 407 engines really had the power and would run thousands of hours before needing overhaul.
C.L.
10-13-2001 15:18:25
 Re: Re: Re: Re: Re: Re: dry-ssleeve engines in reply to J.D. Humm, 10-13-2001 10:24:35
did the D-312 have dry sleeves?
Scott
11-26-2003 20:41:56
 Re: Re: Re: Re: Re: Re: Re: dry-ssleeve engines in reply to C.L., 10-13-2001 15:18:25
The D-312 was a american built wet sleeve engine. It shared many parts with the 400 series engine family used in the bigger tractors.
J.D. Humm
10-14-2001 07:41:39
You know, I don't know. Wasn't it more of a German type Diesel? That's the one the 666 and 686 had? I'll bet it is wet sleeved but can't say for sure. Guess I'll have to study my IH history a little harder. Shame on me.
