Farmall H live hydraulics
Mikek
10-16-2001 19:11:57
Have a 1940 Farmall H want to convert to live hyd.Would like to know what is needed to convert other than the pump.Tractor has a Magneto.Thanks
wh
10-17-2001 06:13:55
 Re: Farmall H live hydraulics in reply to Mikek, 10-16-2001 19:11:57
installed one on a 45 H 12 years ago. must have close to 900 hours on it. bought everything needed at bates Corporation in bourbon, In. bought a new pump (super h/300), used timing gear cover for same, port block for line to connect to pump. bougth line locally when i knew what I needed. used the belly pump for resivoir, just fill it as full as you can.
Jim
10-17-2001 05:23:17
I have an M&W live pump on my '47 H. Rather than make the mods on the oil filter, you can install a delco distributor that is vertical instead of horizontal.
Also, the pump from a SM won't fit. The pump from a 300 will fit but you have to change the timing cover.
I don't know about the W-4, but it should fit as it's the same engine.
Good luck !
Jim
10-17-2001 08:52:56
 Re: Re: Farmall H live hydraulics in reply to Jim, 10-17-2001 05:23:17
I forgot about the reservoir...I used my belly pump but took out the pump and put a steel plate over it to increase the capacity. I have a 3pt hitch, a loader and power steering all running from my pump and have no problems.
Jim Guarino, Agri-Services 716-937-6618
10-17-2001 04:07:34
I installed a M&W live hydraulic pump several years ago on my 1941 H. I had done some research prior to that, and I believe that the pump from a Super H or 300 will fit. I have since found out from reading parts books, that IH had a live hydraulic kit for the W4 tractors. A pump from one of those kits will be a direct fit. Because of the length of the live pump, the long oil filter housing may interfere with the spark plug wires. I had to install a remote oil filter, and I also had to grind the oil pump drive bulge in the block for pump clearance. It is possible to use the original belly pump as a reservoir, but it may not hold enough oil for use with a loader. An open center control valve will also be needed. It is good practice to install a remote spin-on filter in the return line from your control valve. I use an all hydraulic loader with this tractor, and I have been using the live pump since 1979 with no problems.
Corky
10-16-2001 19:47:08
you mneed a live pump off of a M spoolvalve holding tank for fluid.then you will be set
Cork
10-16-2001 20:04:36
 Re: Re: Farmall H live hydraulics in reply to Corky, 10-16-2001 19:47:08
Red sorry if that didnt sound right but you know a model H better than anyone.
