snap ring found in rearend of 3414
C.B.(MO)
11-04-2001 15:29:01
I have a 3414 back hoe loader,I took off the cover under the seat to replace the gasget and gear oil,I found a broken snap ring in the bottom it's about 1 1/2 " external. everything works fine. just would like to know where it might have went. any suggestions appreciated
tbh2a
01-04-2006 21:38:24
 Re: snap ring found in rearend of 3414 in reply to C.B.(MO), 11-04-2001 15:29:01
I've got a 3414 and have completely restored it. Mine does not have a pto, I completely went through the transmission due to a busted gear, there are no snap rings in the transmission other than the 3" snap rings that go to the axles there are 2 of them. They are behind the 2 large drive gears. this snap ring that you described 1.5" probably got in the gear box by someone dropping it in there, the shifter has a 1.5" external snap ring on it, this tractor's gear shifter came with two locking methods being either a snap ring external or a cotter key, the order on the shifter assembly is rubber seal, water cap, rubber 0-ring, washer, spring, washer, snap ring, I busted a gear by turning the wheel on asphalt while the rearend was locked. something had to give.
If anyone could help me with mine, I do not have an original seat, I would appreciate a photo e-mailed to me of how the seat bolts to the cap on the transmission, when I got it the seat was welded on it. my e-mail is tbh2a@yahoo.com
Jim
11-05-2001 16:07:55
Found one snap ring in the parts book, it is on the lower transmision shaft, holds bearing in place. Difference between constant running PTO and PTO with a two stage clutch. Jim
C.B.(MO)
11-06-2001 17:02:52
 Re: Re: snap ring found in rearend of 3414 in reply to Jim, 11-05-2001 16:07:55
this one doesnt have any pto. theres no rattle or odd noise, think will just run it for now and watch it close, the tractor probably doesnt get run 30 hrs in a year ,chances are it'll run forever without that snap ring. thanks for reply
exploded view in.
11-05-2001 06:31:31
.the parts manual should show all parts. dealer may also have a better exploded view? r.
C.B.(MO)
11-05-2001 15:42:58
 Re: Re: snap ring found in rearend of 3414 in reply to exploded view in., 11-05-2001 06:31:31
dont have an exploded view to look at
