Order Farmall Cub Parts Online
Rear axle drive housing for cub.
david
12-02-2001 17:52:11
We have a 1948 farmall cub tractor we were wondering were the fill plugs for the rear axle drive housings are located.
Phlogiston
12-02-2001 18:43:17
 Re: rear axle drive housing for cub. in reply to david, 12-02-2001 17:52:11
They are locted about 2 inches above the axle pans on the inside of the tractor. They have a recessed square head opening. One is toward the front of the final drive, the other side is toward the rear. If you can't see them, scrap off the grease and dirt. They are there.
Phlogiston.
David
12-02-2001 19:00:36
 Re: Re: rear axle drive housing for cub. in reply to Phlogiston, 12-02-2001 18:43:17
Phlogiston, THANK YOU for the information. From:David
Bigdog
12-03-2001 06:03:58
 Re: Re: Re: rear axle drive housing for cub. in reply to David, 12-02-2001 19:00:36
As I recall, you'll probably have to move the drawbar out of the way to get to the one on the left. Just use a 1/2" ratchet drive to loosen it.
kenny
08-25-2003 21:59:31
 Re: Re: Re: Re: rear axle drive housing for cub. in reply to Bigdog, 12-03-2001 06:03:58
Can you give me any imformation on changing the rear axle seals on a IH cub?leaking pretty bad.
