Replacement Parts for Norden Wide Front???
Jeff H
12-11-2001 06:11:41
The stub axle on IH 460 front end broke after an encounter with a hole yesterday. Any ideas other than having a new axle machined and welded to the existing spindle???
Thanks for any help!
-Jeff
Terry Brenk
11-10-2004 10:58:15
 Re: Replacement Parts for Norden Wide Front??? in reply to Jeff H, 12-11-2001 06:11:41
I have a John Deere 620, with a Noreden Wide Front. I am trying find a location as to where I might be able to purchase new outer tie rod ends. Also, possibly the inner tie rod and shaft. If anyone can help, I would certainly appreciate it. Thank you.
Kansas Farm Boy
01-31-2002 22:33:22
It is Norden Wide Front Axle - which mainly replaced the tricycle front end on a variety of brand name tractors; into a more stable and usable front end. The Norden Axle was later manufactured in Russell, Kansas- by Mashburn Inc., and distributed by various implement dealers and Montgomrey Wards up into the the late 1970's as steel prices verus demand made this product obsolete, during the times farming took a great devistation. Thousands of these front end went to the farm country in ILL, IA, Neb., Ind.Oh and Missouri- as they were used for row cropping. Any machine shop should easily be able to manufacture a replacement part of your axle--as well as alot should be found pretty much intact at tractor junkyards. I might add the jigs to these axels are laying behind a barn in the Russell area to this date.
12-11-2001 10:42:14
THERE SHOULD BE LOT OF THOSE SPINPLES IN THE WRECKING YARDS. THAT AXLE WAS USE ON MORE THAN THE 460 MODEL. $165 SOUNDES TO STEEP TO ME. GOOD LUCK
Don L.
12-11-2001 06:34:02
I will make you a NEW spindle from a blank for $165.00. I need your broken part to go off. Don L.
ph 507 433 0073 Austin mn
Rusty Acre tractor parts
18024 540th ave
Austin Mn 55912
