IH 674 Hyd. Help!!
Del MI.
12-27-2001 18:01:14
Rear lift arms stuck in up position.Power steering works after a few min. run time.Loader lifts s o s l o w l y.Relief valves checked OK.Fluid & filter changed.Had water in fluid.Prev owner said rear lift was working erractic and hyd. pump was whinning alot when everything quit working.(He was using it in real cold weather) Pulled pump and everything looks ok.Still can't get lift arms down. Ideas??? Thanks
Donsony
04-26-2005 23:55:26
 Re: IH 674 Hyd. Help!! in reply to Del MI., 12-27-2001 18:01:14
The filter for the main Hydraulics has small ice particles in it,
Replace it or just take it off and warm it up, Dry it out,
or run with out it for a short time
