International 660
Jack
12-30-2001 19:49:10
I have decided that this is the machine for me. Only problem is, what are they worth? A good, running, strong 660.
Dann
12-31-2001 17:02:11
 Re: International 660 in reply to Jack, 12-30-2001 19:49:10
Jack: Went to 3 different sales in 3 different areas No. Ind, So. Ind West Ky watched 3 660s sell none ran, 1 had a cracked block looked good other wise,$1000.00 1 stuck all their tires fair $1500.00 The other one was junk no starter, no batteries, seat rusted off gauges broke out radiator dry rims rusted bad dented and dinged hood grill pushed in lights missing side chrome gone $775.00 So if you know where I can find a nice one cheap! let me know! Hope this Help you with your decision Lots of Luck! Happy New Year! Dann
BenO
05-02-2004 08:54:44
 Re: Re: International 660 in reply to Dann, 12-31-2001 17:02:11
I bought one at a sale for 1400.00 and it was running with good tin. I had to replace the back tires. You have to look in parts of the country that standard were use in high numbers, like the wheat belt.
Steven@nd
12-30-2001 19:57:39
Sold one complete with good tin this fall. Engine was stuck. Sold for $750. There were only a little over 7000 of these made - definitaly a future collector's dream! RARE!! The F-14 is considered collectable and there were over 30,000 of those made!
A couple words of advice: Expect to find a cracked head, even when they ran good they probably had a crack somewhere in the head. Also, if you overhaul be very sure to check the block deck and the head for straightness. Dad put 5 headgaskets in his 560 one year because the head was slightly warped.
My opinion on what it is worth: Good running condition 660 diesel should be worth around $3500 to $5000 depending on where you are from. Expect to pay more for a 660 gas as they are the rarest. (Here they are worth about $350 not running and under $1000 running)
Steven
