C153 in a Farmall C????
Dave_Id
01-05-2002 20:15:56
My late C's 123 engine is tired. I have a chance to pick up an engine from an IH275 swather, and I was thinking of rebuilding it and putting it in the C. Anybody ever have an experience with the swather motor in a "C"?
Dale13
01-06-2002 08:39:58
 Re: C153 in a Farmall C???? in reply to Dave_Id, 01-05-2002 20:15:56
Check the archives for this subject,seems I remember talk about using a 153 combine motor.If it is the same as the swather I don't know.
Dave_Id
01-06-2002 09:34:53
 Re: Re: C153 in a Farmall C???? in reply to Dale13, 01-06-2002 08:39:58
I found about 5 postings on the C153. Thanks for the tip. It doesn't sound like it would fit the C, but sure looks like a small engine sitting in the swather. It sure has high revs. Sounds like the whole machine will fly apart any second when cutting hay.
Big diesel
01-06-2002 03:59:41
it won't fit. The 153 is about 2in. wider than the 123 and bolt holes are larger than the 123. A C-135 will fit. where are you located?
ih_bug
01-06-2002 11:41:34
 Re: Re: C153 in a Farmall C???? in reply to Big diesel, 01-06-2002 03:59:41
big diesel, did you happen to measure one out of a 504 tractor? i sold one this fall out of a 93 combine and as near as i could tell it measured the same as a farmall a or c . when the guy went to bolt it up to his farmall 504 it was about 2 inches narrow and he had to make an adapter plate . the original engine was a c153 and the combine engine was a c153
Curt Cooke
01-07-2002 07:16:08
 Re: Re: Re: C153 in a Farmall C???? in reply to ih_bug, 01-06-2002 11:41:34
I put a 153 on a C and another one on a B. In short, they will bolt up. Your challenges will be, 1)pilot hole in the end of the crank, 2) air cleaner and exhaust through your hood problems and 3) cooling system, getting the fan to fit and getting the water inlet and outlets to work out.
Ross J. Lindberg
07-19-2003 17:29:02
 Re: Re: Re: Re: C153 in a Farmall C???? in reply to Curt Cooke, 01-07-2002 07:16:08
Is it possible to find a bellhousing that will bolt up to a C153 engine out of a 230 swather?
I'm putting the engine into a forklift ande need a way to attach the hydrostat to the engine.
