Auxilary hydraulic outlet for an A,B,C, or 130,140 maybe more
Allen Davenport
01-13-2002 19:14:41
Hey folks I have an auxilary valve outlet that bolts onto the hydraulic manifold on a Farmall or International Model A,B,C,or 140, 130 tractor. I removed it from a 1972 model 140. The valve must have been an optional equiptment and provides the tractor with live remote hydraulic pressure for an external cylinder. I want to put it on E-bay and was wandering what kind of a price to expect.
Pete in PA
01-14-2002 08:49:50
 Re: Auxilary hydraulic outlet for an A,B,C, or 130,140 maybe more in reply to Allen Davenport, 01-13-2002 19:14:41
Allen,
I tried to email you, but the link wouldn't work properly... I'm looking for Rockshaft extension arm for Farmall Super-A / 140 . This is the flat "boomerang" shaped piece that attaches to the hydrolic rocker arm. The long end raises and lowers belly mounted instruments, the front short end would handle front mounted implements. If you have one on your 140, would you mind measuring it for me? I fear I may have to make one if I can't find one for sale...
Thanks Pete
Haas
01-14-2002 06:29:01
If this is an IH valve, I don't think it is any good unless the hydraulic manifold(piping that goes to the pump)is with it also. The manifold with remote valve on the IH system was different than the manifold when you did not have the remote. I expect if it is all there, including the manifold you will easily get $100 for it. Not many of those around.
Allen215@aol.com
01-14-2002 18:59:16
 Re: Re: Auxilary hydraulic outlet for an A,B,C, or 130,140 maybe more in reply to Haas, 01-14-2002 06:29:01
Yes, I have the manifold and the auxilary lever assembly to go with the valve. I took it off and put a rocker arm and I am going to make the piece for lifting the Woods mower up. The person before me had gerry rigged a hydraulic cylinder to lift the mower. The appratus looked quite bogus.Thanks for the info.
