H Speeds and Horsepower for stock engine
MH
01-22-2002 18:56:03
Does anyone know the speeds for 1-5 and reverse for a stock 1944 h? Also about what is the horsepower? THANKs
Richard Bossert
09-29-2003 10:59:20
 Re: H Speeds and Horsepower for stock engine in reply to MH, 01-22-2002 18:56:03
I have a question about the stock horsepower in a 1997 ford 351 ci(5.8 lt)
Harold H
01-22-2002 19:09:39
Nebraska test #333; 26.20 belt hp, 24.17 db hp, maximum pull 3603 lbs at 2.06 mph. Speeds; 1st 2 1/2, 2nd 3 3/8, 3rd 4 1/8, 4th 5 1/8, 5th 15 5/8, reverse 2 7/8.
Harold H
Mike ISW
01-22-2002 19:07:18
1st=2 5/8mph 2nd=3mph 3rd=4 1/4mph 4th=5 3/8mph 5th=15 5/8mph reverse=3mph drawbar=25.5hp/gas pto=28hp/gas
Justin - Pa
01-22-2002 19:05:34
According to Guy Fay's book...
Horsepower
Drawbar: 25.5(gas), 22.65(distillate)
PTO: 27.9(gas), 24.34(distillate)
Gear : Speed
1 : 2 5/8 mph
2 : 3 1/2 mph
3 : 4 1/4 mph
4 : 5 3/8 mph
5 : 15 5/8 mph
Reverse : 3 mph
Harold H
01-22-2002 19:22:05
 Re: Re: H Speeds and Horsepower for stock engine in reply to Justin - Pa, 01-22-2002 19:05:34
The reason my figures are a little different is that Guy's horsepower figures are corrected for standard atmospheric conditions and mine are the actual test results (both are listed in the Nebraska test #333). I didn't show distillate hp results from test #334 since you will be using gas. Guy's speeds are different because he listed the speeds for tractors equipped with 51 x 6 steel rear wheels and I listed speeds for tractor equipped with 10 x 38 pneumatic rear tires.
Harold H
jared rigert
01-23-2002 11:15:30
 Re: Re: Re: H Speeds and Horsepower for stock engine in reply to Harold H, 01-22-2002 19:22:05
I have a 1952 h and it will go 35 mph but it has 40 inch rubber and the governer turned up so it will run 2000 rpms
JWC
01-23-2002 17:25:06
 Re: Re: Re: Re: H Speeds and Horsepower for stock engine in reply to jared rigert, 01-23-2002 11:15:30
Jared,
My grandfather raised cattle and grew corn and tobacco in east central Kentucky. He used a Super H until he replaced it with a new 424 in the early 60's. I was to young to remember this tractor. but he always claimed that it would exceed 30 mph. I grew up in AL and spent time on our H and a neighbors Super H. Both of them would run close to twenty miles an hour. Even at 20 mph it is quite a ride. What does 35 feel like?
Jimbub
01-23-2002 15:46:40
Boy, Jared that sounds fun.My stock H about bounced me off on bumps once,I don;t know if I could take that fun anymore!
